I'm wanting to get a fan controller or my next upgrade and I found a couple that I like and I'm looking to see which one will be better in my case and if you know of any decent cases that are mostly white that are under $120 cad that has most of the features of the Dukase (I like the 2.5" bay on the PSU shroud)
My case: https://www.newegg.ca/Product/Product.aspx?Item=N82E16811853036&ignorebbr=1
Aerocool: https://www.newegg.ca/Product/Product.aspx?Item=N82E16811999279&cm_re=fan_controller-_-11-999-279-_-Product
1st PC Corp (thats the name dik why though):https://www.newegg.ca/Product/Product.aspx?Item=N82E16811997140&cm_re=fan_controller-_-11-997-140-_-Product
Bitfenix (its white so it will go with it more):https://www.newegg.ca/Product/Product.aspx?Item=N82E16811997085&cm_re=fan_controller-_-11-997-085-_-Product
NZXT:https://www.newegg.ca/Product/Product.aspx?Item=9SIA9H54677523&cm_re=fan_controller-_-9SIA9H54677523-_-Product
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/817025-fan-controllers/
