Today i built a pc with the following parts:
Asus prime B350-Plus ATX
Kingston 120gb ssd
Crucial ballistix sport 2400MHz 2x4gb
Ryzen 3 1200
After putting it all together the system lights up normally but it won't display anything.
I wast thinking could this be a problem with the ram compatibility or something else.
I also don't have my graphics card in yet so is that the reason?
This is my first build so i'm not that experienced in this stuff.
Thanx in advance!
https://linustechtips.com/topic/816059-ryzen-system-wont-boot-up/
That would be the problem, current ryzen cpus dont have integrated graphics. The video outputs on the motherboard are for the apus that will come out later.
After you get the gpu all should be well.
Yea, ryzen cpu's dont come with onboard graphics.
