Stuck on post screen with error code 64
Solved by 3rrant,
1 minute ago, Sanchit_technogeek said:yes, its stable! I am overclocking this time by changing the bclk for fine tuning, I guess that may be the problem?
Yes, it is likely that the problem lies on the voltage or frequency of your sata/usb controller. You could try, if you mobo has a separated one, to use USB connected to that one instead and keeping the OC on the CPU. Otherwise you have to reduce the clock or better tune the Voltage.
