so i happened to wander over to the Intel ARK website, and looked up my CPU. i noticed that the max temp is set to 71c (160f). so is that the point where it starts thermal throttling, or will it do much more than throttle back if it ever gets that hot?
https://linustechtips.com/topic/815037-heat/
What cpu do you have?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/815037-heat/#findComment-10224853
Hello! In order for us to tailor support for your question, may we please know that of your CPU and cooler?
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/815037-heat/#findComment-10224867
T case(the temp listed on ark) is not the same as the temp you read in software, it is the max temp reading at the heat spreader. when you measure your temp via bios or software it is reading it from a sensor very close to the cores of your cpu and because of this gives a higher reading. your i5 6500 will go 95+ deg before it will start to throttle, but i would not run my cpu that hot, below 80 is a good and 85 although not ideal is acceptable.
https://linustechtips.com/topic/815037-heat/#findComment-10224972
Quote
it is a 6th gen intel i-5 6500. according to the specs in ark, that is what it says. i thought it was 100c before  it would throttle back to idle as well. maybe i am misunderstanding something?
oh, i am just running the stock cooler. so far, the hottest it has gotten is 37c.
https://linustechtips.com/topic/815037-heat/#findComment-10224973
