Hi there fellow users.
Today a weird idea came in my mind.
At the moment my father owns a Lenovo 3000 N200 laptop with an Intel Celeron 550 CPU in it, running at 2.00ghz (single core) ( I know. The laptop is old and I should go and upgrade it)
I did some research on the internet and I've seen that some people 'modded' their laptop and did a CPU swap. They've placed a T7500 or T9300 instead of the Celeron 550.
BUT! There's always a but. xD I've seen that Celeron 550 uses PPGA778 whilst the Intel core 2 duo T9300 uses the PGA778.(only a P misses from the IntelCore2Duo's socket LOL) The question here is: Will the T9300 work on the laptop I have? I'd like to be sure that it works/not works before doing this because I do not want to spend money on something that wouldn't work at all.
PS: Some guy from a forum said that T9300 won't work on 550's place because T9300 has a higher voltage and some other things different than the 550. That might be true or not, that's why I am here and asking for other's opinion.
Another question is: Is it worth updating this laptop? Because at the moment I do not have the money that I need to buy a new laptop(which will be an 700$ Acer with I5, 950M, 8gigs of ram and SSD probably)
Third question would be:
How much would I get on a PC that I'd like to sell, in order buy switch to ryzen.
The build I'd like to sell is the one that I have atm, but without the GPU, PSU.
So:
Case: Spire Coolbox 202;
CPU: AMD ahtlon II 880k;
Motherboard: Gigabyte F2 A88X-D3HP;
PSU: Spire PSU rated at 430W;
HDD: Western Digital Black 500gb Sata 3;
RAM: Kingmax 8GB(2x4) DDR3, 1600mhz.
GPU: Gigabyte nVidia GT430 2gb GDDR3;
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/814838-laptop-cpu-upgrade/
First of all, your old laptop is worth disposing. Maybe scrap the RAM, HDD and maybe monitor out before dumping it.
Secondly, do you really need a gaming laptop? A powerful desktop and cheap, portable laptop seems to be what fits your budget. Otherwise , throw all your budget on a laptop and only buy a monitor for use at home.
Lastly, I'd pay at most $130 for the PC. It's no longer good for any games, and that's how much I'd pay for a used office work machine.
Desktop benching:
https://linustechtips.com/topic/814838-laptop-cpu-upgrade/#findComment-10222352
No longer good for any games? 880k is a fm2+ cpu running at @ 4.2 to 4.5 ghz.
It can run each AAA title with no problems while paired with the 1050ti that I have. You surely misunderstood about what CPU I am talking about.
TO BE UPGRADED:
https://linustechtips.com/topic/814838-laptop-cpu-upgrade/#findComment-10222497
