now i have to choose between i5 7500 & 1500X  (the only 2 available to my budget)
I5 7500 = 203$
B250M = 114$
DDR4 2400mhz = 66.5$
Ryzen 1500X = 211$
Asus PRIME B350-PLUS= 127.5$
DDR4 2400mhz = 66.5$ / 3000mhz = 80.5$
note that im building it for a pure gaming.
do i really need 3000mhz ram for that ryzen cpu ? or 2400mhz just fine?
hope you help me to choose which one should i pick.
P.S: im going to play on 1080p 60hz monitor + 1060 6GB GPU
https://linustechtips.com/topic/813396-a-little-help/
Ryzen 3's NDA lifted this morning and its significantly cheaper than both systems totaled
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/813396-a-little-help/#findComment-10207152
5 minutes ago, TheBeastPC said:
Yes, but it clearly states in his post that he only has 2 available options within his budget.
But its only 4 days until you can order it
https://linustechtips.com/topic/813396-a-little-help/#findComment-10207178
if you have to go only with one of these 2 I'll go with i5-7500 .
the 2 CPUs are rather close in performance to each other and for you stated you're going to building it for a pure gaming ...
well in my op I go with intel when it's just gaming .
you might use a computer for streaming games, video editing, image editing.... The 1500X is likely to do as well or better than the i5-7500.
for the ram 2400mhz is good considering the CPUs you're going with ,not a big noticeable difference between 2400 and 3000 on this scale so go with what you prefer.
so it's your choice
https://linustechtips.com/topic/813396-a-little-help/#findComment-10208285
