14 minutes ago, Alaradia said:
side speakers, bass,digital audio. you also could have checked your motherboard's manual it lists all the ports and what they do the orange and black are used for 7.1 surround sound
5 minutes ago, Dr. KEK said:
most high end speakers have digital audio. for example, my klipsch system plugs optical from the TV to the speakers
Thanks for answering guys I was planning to buy this mic:
http://www.aliexpress.com/item/BM-800-Condenser-Sound-Recording-Microphone-with-Shock-Mount-for-Radio-Braodcasting/32428415371.html
And was wondering if this sockets are for mics.
And also another question do I need to have phantom power ( What brand do you suggest ) for this mic?, And also is it ok to plug it in directly into my mic socket? Because I have no soundcards.
MY mobo is ASUS ROG STRIX Z270H Gaming
https://linustechtips.com/topic/810096-what-does-sockets-do/#findComment-10170534
2 minutes ago, Dr. KEK said:
plug it into the pink port, usually pink is microphone. the item on aliexpress comes with an adapter that will fit your computer plug
I mean is it ok to plug it in directly?, Some people say I need a phantom power or a usb soundcard.
Will my board can run this mic without any physical errors?
https://linustechtips.com/topic/810096-what-does-sockets-do/#findComment-10170548
it won't hurt it since the microphone doesn't have power or anything that could cause damage to the computer.
Thank You !
It's my first time using mic's like this so better know things better starting up thank you again.
https://linustechtips.com/topic/810096-what-does-sockets-do/#findComment-10170567
it should work the actual product does not mention phantom power. though i'm not sure
https://linustechtips.com/topic/810096-what-does-sockets-do/#findComment-10170617
