Whenever my mom is watching Netflix, or my brother is playing PS4, my ping gets unbearably high in CS:GO and I don't know how to fix it, I'm using an Arris SBG6700-AC router currently, and I connect through wifi. What should I do/buy to fix this? would Ethernet help? What about a Tri-band router?
https://linustechtips.com/topic/809223-netflix-and-lag/
Maybe, but it's probably just a lack of bandwidth to do all of those things at once. Back when I had a 10 Mbps down/1 Mbps up connection, the same thing used to happen to me. The solution in my case was faster internet service.
http://www.speedtest.net/
https://linustechtips.com/topic/809223-netflix-and-lag/#findComment-10161186
Just now, mdthompson2001 said:
@Billy_Mays here's a speedtest, we're paying for 60mbps so idk why I'm only getting 40 rn, because my mom's not here and my brother's only playing mario maker.IMG_7627.thumb.PNG.ba3c6f2b2962b9db528500dde60e2ce5.PNG
Is that a local one?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/809223-netflix-and-lag/#findComment-10161194
1 minute ago, mdthompson2001 said:
@Billy_Mays Idk where Germantown is but I'm in WI
Ok Mario Maker doesnt take up 20mbps and is anything downloading in the background?
https://linustechtips.com/topic/809223-netflix-and-lag/#findComment-10161209
Even 40Mbps is more than enough to stream and game to several computers at once.
Is everything wireless or is the gaming and streaming done over wired and you're on wireless?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/809223-netflix-and-lag/#findComment-10161210
@Lurick Everything is wireless
That would explain it.
Since wireless can only send or receive and have multiple heavy bandwidth things on the network can bog it down. If I remember right, wireless is essentially divided into time slices and the more data being sent the more slices it will consume and in addition it can only send or receive, not both, so if someone is sending or receiving everything else has to wait. You don't have that with ethernet so if you can hook up via wired then you shouldn't have any more issues.
Prior Build Log/PC:
https://linustechtips.com/topic/809223-netflix-and-lag/#findComment-10161265
