15 minutes ago, Cl1362 said:
Would having a USB hub connected to my motherboard io affect the performance of my peripherals?
Thinking of adding a hub either type C or USB 3.0 Mainly for cable management
Any suggestions would be appreciated.
Depend on the peripherals. If you add a USB to USB hub (like 1 port in, 4 out) and connect 4 HDD to these AND use them at the same time, ofc they will split bandwith around.
If instead you use keyboard+mouse or webcam, you shouldn't notice any difference. However, I had issues with Corsair Saber and Strafe that did not power up using a PCI-E to 4x USB3.0 port, for some reasons.
https://linustechtips.com/topic/809208-peripherals-and-usb-hub/#findComment-10161020
