I just built me a new computer, and its amazing, but the only problem I have is, if I put it in sleep mode, and wake it back up it boots up fine, but when I try to open google to search something it doesn't search, it just sits there and loads for a while and does nothing. it also does the same thing for steam. it will just sit there and say there was an error. but if I reboot my system, it works perfectly fine. any fix for this?
https://linustechtips.com/topic/808328-pc-trouble-after-sleep-mode/
REEEEEEEEEEEPOST
seriously, your old post is still on the sidebar. don't repost the same question twice, especially if your old thread is still active.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
