Cable Sleeve Sizes
Go to solution Solved by W-L,
8 hours ago, RyeIII said:
What size should I use with the following wires:
4-pin PWM Fan
Front-panel connectors
Internal USB 2.0 wire
Thanks
In order these are approx sizes that work well, The size for the USB can vary as some have thicker shielding and insulation than others.
4mm (1/8")
2-4mm ( 1/8 - 1/16")
8-10mm (5/16" -3/8" )
4-pin PWM Fan
Thanks
Ryzen  5 3600 | ASUS Strix B450i Strix | G-Skill Trident Z RGB 16gb 3200mhz
Gigabyte RTX 2070 Super OC | Samsung 970 EVO Plus 500gb | NZXT H200i | NZXT x52 | Corsair RM650x
https://linustechtips.com/topic/805279-cable-sleeve-sizes/
4-pin PWM Fan
Thanks
4mm (1/8")
https://linustechtips.com/topic/805279-cable-sleeve-sizes/#findComment-10120202
