PWM splitter
Solved by KenjiUmino,
5 minutes ago, Alcet said:I bought 3 pwm Y splitters and it said in the description that its 4pin to 4pin. When i checked, its 4pin to one which has 4 pins and another which has only 3 pins if that makes sense. Is that normal?
yep, that is normal - the one wire that is missing on the second connector is for the RPM signal. you can only read RPM from ONE fan at a time per mainboard connector so it does not make sense to run this wire into both connectors
