Hello,
I've owned my Steelseries Rival 300 for about a year now, absolutely love it, works great, except.. recently, whenever I click in the mouse wheel(to open a link in a new tab, for example) it usually either double clicks or quadruple click(yes, clicking once on a link opens it 4 times). The mouse hasn't taken any physical abuse, just normal wear and tear. Any ideas on how I could solve this? It's driving me nuts.
Thanks.
https://linustechtips.com/topic/804925-scroll-wheel-clicking-issue/
Switching out the switch inside of the mouse, or get a new one.
Had the same kind of problem with the logitech mx performance... mouse buttons did the same. Bought omron switches that fit and soldered the defective out and new ones in... works like a charm.
But can't say if it is possible for your rodent.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
Ah, I was hoping it'd be a software issue, oh well.
I was looking at local discounts recently, saw that you can get a G900 for 60 euros, might give that thing a swing.
Thanks.
