Well i was overclocking my i5-2500k I got to a stable 4 on all cores and when I was running windows experience index I heard a large whiring sound when is was running the cpu at max settings.
My Specs:
CPU i5 2500k
Motherboard G1 Sniper 3
PSU Silver Stone 850 watt
Noctua 9 cooler
https://linustechtips.com/topic/804-coil-whir-cpu-overclocking/
Whiring as in whoosh sound like air moving or like coil whining ?
If whoosh as in air moving then its fine cause windows experience index puts some strain on your cpu at some point and the fans will ramp up for a while.
You can try P95 small fft's torture for a while and see if the same sound occurs (make sure you check your temps tho so you dont harm your pc, you dont wanna go over 85).
Best wishes
- cheti
https://linustechtips.com/topic/804-coil-whir-cpu-overclocking/#findComment-9861
If its after overclocking then its probably your motherboard.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/804-coil-whir-cpu-overclocking/#findComment-12198
