Hello LTT forum!
First of all I would like to point out that I have read the README regarding no POST.
I am helping a friend build his new computer and we cannot get anything to show up on the display.
The MOBO LED's are turning on, GPU LED's are turning on, both chassis fans turn on, CPU fan turns on, but nothing is displayed. I plugged in a keyboard to see if I could force it into bios and the keyboard LED's light up as well, I am also able to turn caps lock on and off.
Here are the specs:
i7-7700k
16GB (8x2) Corsair Vengeance DDR4 3000MHz
Asrock Z270 Extreme4
Corsair RM750x
Samsung 850 Evo 500GB
Samsung 840 Evo 500GB
GTX 1080ti
Fractal Design Define C
Here are the steps we have tried:
- both RAM sticks in slot A1 B1 - reseated as well
- both RAM sticks in slot A2 B2 - reseated as well
- Single RAM stick in A1, A2, B1, B2. (both sticks tried)
- All cables reseated in MOBO
- All cables reseated in PSU
- Different combinations of CPU-fan headers and CHA-fan headers (CPU fan in both CPU1 and CPU2 spots, etc.)
- All Case connectors reconnected
- HDMI on MOBO
- DVI on MOBO
- HDMI on GPU
- Displayport on GPU
- Without GPU
- CMOS Battery removed
- Only 1 SSD
- Both SSD's
https://linustechtips.com/topic/803716-new-build-no-post-need-help/
are you plugged into the GPU for the screen?
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
I have tried the following screen connections
screen to gpu with HDMI
screen to gpu with displayport
screen to MOBO with HDMI
screen to MOBO with DVI
also tried 2 different monitors
it's just GPU not mobo you don't plug into mobo when you have a gpu in.
i'm asking this because if you can turn capslock on and off it's most likely you're fully booted just not seeing the image
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
