Ok, so I was upgrading my old Asus X550J to an SSD. So, i took the drive out of the package, slapped it in the drive bay, replacing the old HDD. Then, I plugged in my bootable media, and it wouldnt let me boot from it. It shows in the BIOS that there is nothing I could boot from.
My SSD is the samgsung 850 Evo if that means anything to my problem.
This is my first time upgrading a laptop, so please tell me my noob mistake.
Main Laptop: Google Pixelbook
Dev mode w/ Cross Enabled
PC: Ryzen 7
1700x / 32GB 2667 / GTX 1080 / 1.5 TB of SSDs / 1TB of HDDs
Monitor: AW3418DW Ultrawide
120hz / 3440x1440 / RGB / Amazonbasics Dual Monitor Arm
2nd Monitor: Dell U2515hx
25 inches / 1440p / Portrait / Amazonbasics Dual Monitor Arm
https://linustechtips.com/topic/803593-need-help-upgrading-to-ssdcant-boot/
What exactly is your "bootable media"?
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Windows 10 on a 16GB flash drive.
Made it with the media creation tool.
PC: Ryzen 7
Go into your BIOS, disable secure boot, and switch to CSM.
Thanks!
that worked!
=D
PC: Ryzen 7
Thanks!
that worked!
=D
No problem :)
No problem :)
Wait
its saying that no drive is found...
PC: Ryzen 7
1 minute ago, TrevMCC38 said:
Wait
Can you connect it to another computer?  You may have to initialize it as GPT by opening Disk Management in Windows.
Can you connect it to another computer?  You may have to initialize it as GPT.
I dont have another computer i can connect it to
PC: Ryzen 7
Are you talking about when selecting a place to install Windows?
yes
PC: Ryzen 7
yes
You'll need to initialize it through command line.  Instead of installing, go to Troubleshoot and open Command Prompt.  Then follow the directions here.  Use Method 1 and start at the line that says " So, here you should typelist disk first"
Assuming you can install it after that, it will reboot several times.  After the first time it reboots you'll need to change it back to UEFI.
I have never used the command prompt before and i have no idea what its telling me to do.
PC: Ryzen 7
Ok, wait, I got it to diskpart
it says disk 1 is invalad
PC: Ryzen 7
All the things you have to type are in red boxes
Do you have a phone that you can use to take a picture of the screen?
Ok, in list disk, it shows only my flash drive
PC: Ryzen 7
Your SSD probably isn't connected properly then.
IMG_0012.mp4
PC: Ryzen 7
PC: Ryzen 7
Well you're connecting it right. My best suggestion is that you buy an enclosure.  Put the SSD in it, boot up your hard drive (remember to switch back to UEFI mode first), open up Disk Management, and initialize the drive as GPT.  If that doesn't work, it means the drive is bad.
I know it sucks to buy more stuff, but on the bright side, you can use that enclosure on your old hard drive.  That will let you use it as a backup.
The old HDD doesnt work anymore
PC: Ryzen 7
That sucks.  Maybe you can sell the enclosure to someone when you're done with it.  You'll have to get access to someone else's computer to initialize it.  It only takes 2 seconds.
i mean im on my desktop rn, so what  would i need to do to initialize it
PC: Ryzen 7
