I am using a rx 460 2 gb model and in order to work with my vga monitor I bought this adapter https://www.emag.bg/konvertor-hdmi-kym-vga-hama-54569-hama-54569/pd/DPXQP2BBM/?gclid=Cj0KCQjwytLKBRCXARIsAPchlXqTdABSbSQ-_Yk6pmZumGU3Ap1pyAG51445fNRGV5dE1qaToLor8CMaAlENEALw_wcB&ref_cmp=ps&emagi_click_id=53e164bb56935f0148aec5286a309992
When I start up a game it crashes. In less demanding like league it takes like 30 seconds to freze. Is it from the adapter?
Or a problem from the driver help
Edited by Combat
https://linustechtips.com/topic/802131-rx-460-problem/
1 minute ago, Combat said:
I updated them and reinstalled and now im installing them for the 3rd time.. The latest ones from the amd website.
Have you tried reinstalling the game?
i5 6600k and GTX 1070 but I play 1600-900. 1440p BABY!
Still, don't put too much faith in my buying decisions. xD
https://linustechtips.com/topic/802131-rx-460-problem/#findComment-10085771
You must use Clean uninstaller program, don't uninstall it manually.
Challenger Tier at League of Legends since Season 5.
https://linustechtips.com/topic/802131-rx-460-problem/#findComment-10085778
Just now, Combat said:
How to clean unistall?
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Extract to desktop.
Run it.
Run it again from Uninstaller exe
From Normal select to Safe Boot
Launch.
Your PC will go into Safe Mode and launch the program.
Enjoy.
https://linustechtips.com/topic/802131-rx-460-problem/#findComment-10085803
Extract to desktop.
Run it.
Launch.
Enjoy.
Cleaned uninstalled all the drivers and installing the amd atm.
https://linustechtips.com/topic/802131-rx-460-problem/#findComment-10085912
