I am looking for a build that is around the $800 mark (+/- $100) that includes ram, mobo, and CPU. This is only for gaming and minor things such as school work. I play mostly CS:GO, PubG, Rust, RL, Dayz, Arma 3, and other games like those. I prefer a Nvidia graphics card and Intel, but I can be persuaded by a AMD build seeing as they are on the come up. Thanks much in advance!
https://linustechtips.com/topic/798028-800~-build-help/
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($157.49 @ SuperBiiz)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($83.98 @ Newegg)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($59.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: MSI - GeForce GTX 1060 6GB 6GB GT OCV1 Video Card  ($249.98 @ Newegg)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($64.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Total: $824.74
Generated by PCPartPicker 2017-06-24 12:28 EDT-0400
https://linustechtips.com/topic/798028-800~-build-help/#findComment-10042360
Total: $824.74
I only need a mobo, RAM, CPU, and GPU. I have every other necessary part. Thanks so much for the build though.
https://linustechtips.com/topic/798028-800~-build-help/#findComment-10042413
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($95.74 @ Amazon)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($119.99 @ Newegg)
Video Card: EVGA - GeForce GTX 1070 8GB FTW Gaming ACX 3.0 Video Card  ($464.98 @ Newegg)
Total: $880.70
Generated by PCPartPicker 2017-06-24 12:55 EDT-0400
https://linustechtips.com/topic/798028-800~-build-help/#findComment-10042432
Total: $880.70
This seems like a pretty solid build, though I'm not too sure about the motherboard.
https://linustechtips.com/topic/798028-800~-build-help/#findComment-10042472
Total: $880.70
Get a 980 ti, it can give the same performance as the 1070 and be $100-$50 cheaper-
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487354&cm_re=980_ti-_-14-487-354-_-Product
You can probably get a better deal than this, but this one seems decent.
https://linustechtips.com/topic/798028-800~-build-help/#findComment-10046158
