So I need to upgrade my router that my ISP gave me cause it's terrible, and I want something really good, as I run a HTPC with a DNLA server on it for streaming around the house, I also have my Gaming PC on the other end of the house so I need good range on the router, on top of that there are loads of devices connecting to it, about about 5 PCs and 5 phones and a printer and a few other things.
I know WiFi Isn't the only option, but it's the easiest for me, and even if I used powerline I'd still have to have wireless for laptops and phones.
I've picked 2 that look really good, but I'm not sure which is best: http://www.amazon.co.uk/dp/B007W16SMO
http://www.amazon.co.uk/dp/B005UGRF16
The Asus one looks like it might have better range because on the external aerials but idk .Any other suggestions?
Thanks guys.
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
https://linustechtips.com/topic/7971-best-wireless-router/
Thanks , yeah I think I will go with the Asus
Main Rig:
Home Server:
https://linustechtips.com/topic/7971-best-wireless-router/#findComment-90017
Thanks guys! Asus sounds good to me
Main Rig:
Home Server:
https://linustechtips.com/topic/7971-best-wireless-router/#findComment-91145
