It started recently random restarts while gaming. Some times as soon as game starts some times at game end and sometimes no restart in full night of gaming. No temperature problems everything is under 65C under full load.
I was hacked 2 days ago (hacker changed my passwords and tried to steal a bunch of money from me) using kasperski zemana and hitmanpro i think i removed him? But the restarts continue. I am using latest drivers.  I built PC myself.
When running CPU stress test no problems when running GPU stress test i get a reset very quick.
Again its random it can take 5 seconds it could take 2 minutes. At time of reset temperature is never more than 55C.
There is no artifacts, altho there are occasional frame drops while gaming. Dips from 120fps to 60-50fps (which never happened before) drop does not represent higher intensity its random.
GPU 1070 Zotac extreme 8GB
PSU CX750 corsair 80+ bronze
Corsair CX750 ATX Power Supply
AC Input Rating DC Output Rating
AC Input: 100V - 240V DC Output +3.3V +5V +12V -12V +5Vsb
Current: 12 - 6A Max Load 25A 25A 62A 0.8A 3.0A
Frequency: 47Hz - 63Hz Maximum Combined Wattage 130W 744W 9.6W 15W
Total Power: 750W
Cpu 6600K
Ram 16GB hyperX
Nothing is overclocked.
Case has 2x12cm 2x10cm fans so fair enough cooling.
cooler master calculator Recommended PSU Wattage:367 W
Linus Forum any suggestions and tips are welcome! Thank you :)
Problem seems to be solved with changing the PSU supposedly the cx750 has a working temperature of up to 30C. Swapped for Evga SuperNova 750W P2 works perfect up to50C.
Edited by Tuzara01
Solved
https://linustechtips.com/topic/794286-pc-restarts-psu-problem-virus-solved/
The virus was Temp\phantomows\bin Csrss.exe and every time kaspersky tried to delete it it reset my pc or crashed so had to use zemana and hitmanpro to remove it. But all 3 programs show nothing left. I used to have network spikes every 3 seconds while idle so i suppose hacker was LIve at the time.
