WiFi problem, Please Help
Go to solution Solved by MonsterHunter280,
5 minutes ago, AntonDVries said:
Should do the job
Sorry to do this, but now it works. I did nothing, I uninstalled my drivers before writing the post, just so that I'd have a fresh start, then it automatically reinstalled the drivers and now everything works. Shocked
A while ago I was having problems with my internet. Some websites would load but others wouldn't. The ones that open are all Google sites. I chalked it down to my router, but when I plugged in a USB dongle it everything worked fine. My phone works fine as well. But my wireless card will only load YouTube and nothing else. I've uninstalled the drivers, swapped the card between PCIe slots and even done a fresh install of everything connected to the card (Not including my OS, which is windows 10). Nothing seems to work. I'd appreciate any help and will gladly give more info if needed. My wireless card is a qualcomm AR9287 with the latest drivers (Version 10.0.0.341). I have tried rolling back the drivers but that didn't work.
Many thanks!
https://linustechtips.com/topic/789243-wifi-problem-please-help/
1 minute ago, AntonDVries said:
It could be that your router is denying some website on a specific ip address. Try to change your ip address for your device or try to reset your router, full reset like it came out of factory. That should do the job I think
How do I change my IP?
https://linustechtips.com/topic/789243-wifi-problem-please-help/#findComment-9943423
Should do the job
https://linustechtips.com/topic/789243-wifi-problem-please-help/#findComment-9943488
LOL
https://linustechtips.com/topic/789243-wifi-problem-please-help/#findComment-9943559
