I'm honestly not sure where this problem topic should go. So this is my best guess, and I do apologize in advance if it's not correct.
My Home Server is where I store all of my backups for my laptops, so when I backup, it's done over the network. Well, two of the laptops went flawlessly. Backed up, finished, then shut down like I selected. But the third one either stops about 6GB in and just sits there saying a time remaining. Or, if it does work past that, it gets to the end and sits with "less than a minute remaining" and doesn't do anything at all. I'm using Acronis True Image 15 that came with the Crucial MX300 SSD that's in the laptop that it's not working on...
I've searched online and I've read and performed the pre/post command VSS disable/enable trick that worked for some. Didn't work for me. Uninstalled/reinstalled the software. Didn't work. Checked to make sure there was no .meta files left behind of the deleted backups that didn't finish. I tried backing up to an external HDD to see if maybe it was the network connection. Hooked it up via LAN rather than wifi as well. The other two laptops worked over wifi and backups were saved over the network. When it locks up during the backup windows itself seems to freeze. I get an error saying windows is not responsive, and nothing works. I have to do a hard shutdown.
Any help would be appreciated. I seem to have exhausted my current knowledge on this.
https://linustechtips.com/topic/789142-acronis-true-image-15-backup-problem/
