windows 10 32 bit to 64 bit problem!!!
By
d0pe_gam!ng
in Windows
in Windows
Solved by Beowulff83,
Assuming that windows now is installed on C drive and you have another partition with all the files you want to save you should just be able to install windows 64 on the C partition and it will not effect your other drive.
Featured Topics
RexCarbon ·
Posted in New Builds and Planning4 -
Victor99 ·
Posted in Storage Devices5 -
2
Megachuggayoshi ·
Posted in New Builds and Planning2 -
3
karmic tr ·
Posted in Troubleshooting1 -
5
1
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
