OK so ill probably go to Reddit with this as well but I need help finding what wires do what on a DDC Pump. Im trying to do some super sketchy water cooled PC using the watercooling parts from a old Powermac G5. Im using one of its pump-block combo things as my waterblock and pump. IDK if it helps but based on my research the pump is made by Laing and the 'model' or whatever on it is PPS-GF40
Please note this is not the normal pump that comes up when you google it.
The pump looks like that. The issue is I cut the connector off. So I need what the wires coming directly out of the pump do.
If anyone can find out or help me that would be great
Breaking things 1 day at a time
https://linustechtips.com/topic/788907-wiring-help-on-pump/
