EVGA individually sleeved cable
Go to solution Solved by shadowbyte,
if the product numbers are the same, the products are most likely identical
however, ymmv
Hey people. I was wondering whether This cable set is compatible with the EVGA G3 PSUs It's not in the title of the product yet on the EVGA website, it says that the set is compatible with G3. Both product numbers are : 100-CR-1300-B9
I know that logically this cable is compatible but I just want to double check and not cause any damage. Thank you very much!
https://linustechtips.com/topic/787990-evga-individually-sleeved-cable/
however, ymmv
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
6 minutes ago, Billy_Mays said:
you can them cheaper on newegg
It's OK since I actually got the white sets which cost the same as newegg and with prime I got it the next day. I did flag it on the amazon website as an incorrect title and they did change it but I was still worried. Anyways thanks
