Hello guys,
I'm planning to build a PC, actually I already bought some parts lol. I need suggestion/advise from you guys.
MOBO: Maximus VIII Ranger (already bought)
CPU: Intel i5 7500 (already bought)
GPU: Strix 1050Ti OC 4gb
RAM: G.Skills Ripjaws V 2x4 8gb
PSU: Seasonic S12II 520 watts (dunno if it is correct)
HDD: Seagate/WD 1TB
CASE: Tecware Alpha or Edge
I'll be using stock cooler FOR NOW
"Bought Maximus but no overclock CPU" yes, Maximus is on sale right now here almost half the price and I will be upgrading this PC to RGB set up so I bought Maximus.
I will upgrade the casing to Corsair 460x when I already have cash.
I'll be using this PC for Mid gaming
Appreciate your help and suggestion!
https://linustechtips.com/topic/787798-building-a-pc-need-advise/
2 minutes ago, MkaiL said:
You do know your z170 motherboard probably needs a bios update for it to work with kabylake processors?
This ^^^
Also, get an RX570 if you can afford it, as it's better than the 1050 Ti in almost everything. Unless you need CUDA or Nvidia software.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Yes, they said I can come back to the store if the BIOS is not updated so they can update it for me. It is just that all i5 Skylake is out of stock.
This build is fine as long as you update that Z170 board
But if you can squeeze a bit more get the Rx 570
CPU: Intel Core i7 10700K 8C/16T @ 5.2GHz All Cores -- CPU Cooler: EK AIO 360 D-RGB
 Motherboard: ASUS ROG STRIX Z490-F Gaming -- RAM: G-Skill Trident Z 32GB (16x2) DDR4-3000
SSD#1: Samsung PM981 256GB -- HDD: Seagate Barracuda 2TB -- GPU: ASUS TUF GAMING RTX 3080 10GB OC MSI GTX 1070 Duke
PSU: FSP Hydro G Pro 850W -- Case: Corsair 275R Airflow Black
Monitor: ASUS TUF Gaming VG27AQ 1440p 165Hz -- Keyboard: Ducky Shine 7 Cherry MX Brown -- Mouse: Logitech G304 K/DA Limited Edition
Phone: iPhone 12 Pro Max 256GB
Headphones: Sony WH-1000XM4 / Apple AirPods 2
Laptop: MacBook Air 2020 M1 8-core CPU / 7-core GPU | 8GB RAM | 256GB SSD
TV: LG B9 OLED TV | Sony HT-X9000F Soundbar
20 minutes ago, ImNotThere said:
If youre set on the 1050ti at least get an msi 4gb oc one as its cheaper
16 minutes ago, Memorizer said:
If you can find a fine refurbished GTX 970, go get one, it's better than the 570 and you can get it for $150 give or take :)
Edit: if you have a freesync monitor, then just go for the 570 :)
Well, it seems that upgrading the BIOS will be my main problem here (if ever they don't upgrade it for me lol)
Do you think a newbie like me can upgrade it myself by watching some videos?
I'll take a look on the GPU's you have suggested guys.
Updating bios is ez, watcha guide on your mobo and youll be fine
Updating BIOS is even easier than installing Windows on modern motherboards
But you need a thumb drive, a working PC to copy the BIOS file in it though
