So I have a 1TB WD Caviar Blue 7200RPM drive and I feel like it is unusually loud considering that it is new. On full load, in a silent room, I very well hear it from 2 meters away and it makes a grinding noise.
Also, when it turns on, it makes a very loud spin up sound. I tested it with SMART and everything seems fine but I just want to know if this is how loud it normally should be?
https://linustechtips.com/topic/785181-loud-hard-drive/
Yes, on load in a silent room you're going to hear the drive spinning. And it's going to make a spin up drive when it hits from zero to fast in a second.
Seems normal to me. Spinning sounds are fine. Audible clicking and scratching is when I'd worry.
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9895710
Some drives are very loud when spinning up and under full load. If you're worried about it, just replace it. As long as it checks out fine in something like CrystalDiskInfo, you should be good.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9895746
23 minutes ago, powerplayer75 said:
What about if I can still hear small grinding even at 10%?
Quote me so I'll see your response sooner, please. It depends on your perception of "grinding". It is bad sounding?
Main System: Phobos
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9895830
1 minute ago, powerplayer75 said:
Sorry, I think It would be best if I got an audio file so let me try that.
Ok, do that.
Main System: Phobos
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9895843
7 hours ago, powerplayer75 said:
Ok this is the sound and at the end thats what it sounds like when it shuts off. You'd probably have to turn up the volume though.
Voice_170527_4.3gp
Sounds okay to me, although you might want to look at how it's mounted in your case? If you can get something to dampen the vibrations it might help matters.
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9897642
Ok. Its been the loudest part in my whole system which is why it bothers me so much. Fan whirring sounds so much better than hard drive grinding,
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9898283
The thing is, with this kind of thing it's often subjective. It sounds like it's okay from the file but that might not really show how loud it is or if it's louder than it should be? (e.g. if it's making all of the right kinds of noises for an average HDD but at the wrong decibel level for the specific drive, it could mean that there's a problem.)
I'm basing the assumption that it's okay on the chirp from the drive (which spiked my audio), unless that chirp coming from the drive (not from the sound-file, from the drive) is ear-piercing where you are, then I'd say the drive is okay...it just might be that it happens to be louder than you're used to.
How many HDD's have you had in the past? Also, what fans do you have in the system, how many, and are they being voltage or PWM controlled (or in some other way slowed down from their maximum speed) ?
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9899869
1
I have had another WD and Hitachi drives in the past. They sounded slightly better than this but the Hitachi drive is about 8 years old so the new WD's shouldnt sound like that. But I have fully determined that the only noise from my pc is from the power supply and hard drive because I temporarily turned off every other fan (including GPU fans) and there was no difference in noise level. Fan noise from PSU and grinding from HDD.
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9902534
If you're that concerned about it then maybe you should return it? if it's still under warranty?
Also, as smashman2000 says upgrading to an SSD will make your system quieter, and will help it feel faster and smoother, but people often also use HDD's for storage space (because SSD's are still quite expensive), so it might not solve the problem unless you fit a new HDD anyway?
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9904402
Thats what I plan to do. Since I have other drives, I will temporarily clone my drive to another one, then I will RMA the drive to WD and then reclone it and see if the noise changes and if the spinup/spindown sounds go away. If it does then great, but if it doesnt then I guess Ill just have to live with it.
https://linustechtips.com/topic/785181-loud-hard-drive/#findComment-9905969
