So I'm looking to buy a monitor but the model doesn't have DP, but it has HDMI 2.0. The monitor supports 4K 60hz 4.4.4, but I hear that in some cases an HDMI 2.0 capable cable may not be able to push these settings. In that case someone suggested using an adapter.
The question is, in what configuration?
HDMI 2.0 Cable with a HDMI to DP adapter?
Or...
DP cable with a HDMI adapter?
Which method is required to make a DP connection to a monitor without a DP port?
https://linustechtips.com/topic/783872-using-a-dphdmi-adaptor-question/
Or...
Using a DisplayPort to HDMI adapter isn't going to give any special advantage over a straight HDMI to HDMI connection unless your graphics card doesn't support HDMI 2.0. Just use a straight HDMI connection.
I'm using a 1080ti, so that shouldn't be a problem.
I'm just concerned that the monitor that I ordered may not push all 4K/10bit/60Hz/4:4:4 with a HDMI 2.0 cable as I've heard that even HDMI 2.0 can just barely push that. But I'm hoping there would be no problem. However in the worst case scenario, someone suggested using a converter adapter to make a DP input I've looked into Amazon JP and found a HDMI to DP converter adapter.
However, my concern is which configuration I need as per thread was intended for. If I understand correctly, converter adapters are more than simple adapters as they actually convert the signal. Noted for being pricier than standard adapters.
https://www.amazon.co.jp/gp/product/B00S0C7QO8/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A3TN4FURJT6SI3 (sorry it's in Japanese)
This is the active converter in question. Would his be enough to push a HDMI 2.0 cable as a DP connection? As in give it the input capabilities of a DP?
There's no reason to use an adapter, if the HDMI 2.0 port on the GPU can't do it then no adapter will be able to do it.
Having said that, HDMI 2.0 should work fine, the monitor will have at least one input capable of doing the full resolution (not all the HDMI ports are always the same, use the correct one). Unless the monitor requires a dual link (two cables) then the HDMI 2.0 will work fine.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
No, if you use a DP to HDMI adapter it will give you the capabilities of an HDMI connection. It's not going to be any better than an actual HDMI connection, you don't get any special extra power by converting from DisplayPort.
4K 60 Hz is within HDMI 2.0 spec, there shouldn't be any problems as long as you get a properly rated cable. Most High Speed HDMI cables should work but if you want to be sure then you can get a Premium HDMI certified cable, which are tested to work at full HDMI 2.0 bandwidth.
I do appreciate people are trying to help... but it's hardly helpful :(
First of all, I'm trying to achieve 4K/10bit/60Hz/4:4:4, this is more than a simple 4K/60Hz.
Let me try ask a different question.
I am using a 1080ti, which has a displayport input. So if I buy a displayport cable and connect one end to the gpu and use a DP to HDMI converter on the other end to connect to the monitor, will that become a displayport connection? Or will it bottlenecked by the converter?
Monitors use RGB color format, which is equivalent to YCbCr 4:4:4. People make a big deal of "4:4:4" in the TV world but it's the everyday standard on computer monitors. HDMI 2.0 is fully capable of 4K 60 Hz 4:4:4. Lower modes like 4K 60 Hz 4:2:0 fall within HDMI 1.4 spec, actually.
Images go from the graphics card to the monitor, so graphics cards have output ports (which send images out) and displays have input ports (which receive images in).
A DisplayPort to HDMI converter makes your graphics card's DisplayPort output act like an HDMI output. Its capabilities aren't going to be any better than an actual HDMI output.
I see... it kinda makes sense.
Guess I'll just live with what I get. Since anything is technically an upgrade for me right now.
You'll be fine just using an HDMI cable, no need to overthink things... HDMI supports up to 4K 60 Hz RGB/4:4:4 at 8 bit. It won't do 10 bit color depth but if the monitor only has HDMI 2.0 and not DisplayPort then I doubt it is supposed to support 4K 60 Hz 10-bit... since that is outside HDMI 2.0 spec.
So I was watching this... and Linus talked about using 2 cables to run a single monitor...???...? Hem???
Is this a thing? Am I able to run x2 HDMI cables to a single monitor to boost bandwidth?
Not unless the monitor is specifically set up to allow that
Fair enough.
Also, which configuration has the better image fidelity?
4:4:4 8bit or 4:2:2 10bit? Apparently that's what you can achieve with the monitor I ordered.
8 minutes ago, xXRaineXx said:
Fair enough.
Always use 4:4:4 when available, 8-bit vs 10 or 12-bit color depth doesn't really affect much.
