Stuck in a loop!
Go to solution Solved by ProRules,
3 hours ago, spadz93 said:
You can't boot into it from bios?
Just fixed, had to flash the file to the disk on key with rufus.
installed clean ver.
Hello guys!
So apperently i run registry verifier from a guide, to fix a specific crash.
It just destroyed the windows.
Can't start it in normal mode, only safe mode works.
So i:
Can't reset my pc option, it gets to an error.
Can't restore point.
Can't use external system recovery img.
Can't run any third party app in safe mode to mount windows img.
I have a usb flashdrive 3.1/3.0 with a windows img on it, so i try to flash by loading it from bios launch device options, and it drops an error code 0xc00000f
So i can't even flash a disk on key.
What can i do here realy?
https://linustechtips.com/topic/783636-stuck-in-a-loop/
Di the software you used back up the registry?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/783636-stuck-in-a-loop/#findComment-9877243
Just now, spadz93 said:
Put the drive on a dock, connect to other computer, back up files and start fresh, at least that's what I'd do. Not sure how much I trust a "registry verifier", especially without a backup
How can i "start fresh" thats what im trying to do all day, but i simply can't access my ISO on the boot flash usb drive, it errors instantly.
Only thing i can do is run safe mode, but i can't run ISO from safe mode obviously, so im literally stuck?
Everything i do errors. all repair/troubleshoot problems, all restore/reset my pc options..
https://linustechtips.com/topic/783636-stuck-in-a-loop/#findComment-9877278
Just now, ProRules said:
Its a windows built tool, something registry viewer maybe, not that third party software, i bet it did.
Then go before the great Google and ask it to enlighten you on how to restore the backup. :D
Mouse: EVGA X17
https://linustechtips.com/topic/783636-stuck-in-a-loop/#findComment-9877292
https://linustechtips.com/topic/783636-stuck-in-a-loop/#findComment-9877339
