overclocking Help, Temps are crazy.
Solved by LogicalDrm,
Well, let me list the issues here:
- OC. Voltages. Those do more for temps than clock speeds. They will play factor.
- Cooler. Like you said, its not wonderful. In fact, there are cheaper air coolers which are better.
- Ambient. Whenever you see review about temps, they are made in 20-25C room. Every degree ambient goes up, so does temps for CPU/GPU. 90C equals 70-75C on cooler ambient temps.
- Prime95. That thing can cause unrealistic temps. Try with some other stress test, like Aida64 or OCCT.
So in all, temps aren't that odd. Just normal for the combination.
