Hi all so im looking to do my first custom watercooling project. Im pretty new to the whole custom loop thing so would like some advice if possible and maybe a partslist?
System/Case:
InWin 303 case
Asrock B150M Mobo
i3 6100
No gpu in the loop right now
things that it will need to be able to do:
1. Be easy to change the motherboard/cpu as right now it will be going in a i3 system but will be upgrading that in the future.
2. Big is good, im looking for the fatest tubing/rads i can use. Not hard tubes.
3. Must have 2 maybe 3 rads - 2x360mm and 1x120mm maybe
4. Preferably will bolt into the case aka no drilling
5. Parts from this website https://www.pbtech.co.nz
can get pics of it if needed
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/775224-inwin-303-custom-loop-advice/
System/Case:
InWin 303 case
Asrock B150M Mobo
i3 6100
Get a better processor first mate, waste of money making a custom loop for a 6100.
Put the loop into your main machine?
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
no thats in a different case. i want the dual 360mm loop in the inwin case. i relise its overkill but my i3 has a heavy overclock so does need good cooling and ill be upgrading at some point anyway.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
How are you overclocking a locked chip.
Zoom H5 + XY-5
Phone - Oneplus 6T
with a asrock board that allows it with an added chip
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Specify board pls, i need to get one if this is the case.
Zoom H5 + XY-5
Phone - Oneplus 6T
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
