USB 2 hub questions
By
NSDUO
in Peripherals
in Peripherals
Solved by W-L,
2 minutes ago, NSDUO said:If I plug a cooler master master keys lite mouse/keyboard combo, a rgb led strip, and maybe a webcam into a four port USB 2.0 hub, would I have any issues especially with the keyboard mouse and webcam?
You will most likely run out of power unless that hub has external power to it.
RipperDoc5456 ·
Posted in Troubleshooting1 -
Nebcs ·
1
FancyPants101 ·
l3eyond ·
1
