Hi
I need usb sound card for record my voice with microphone (jack 3,5)  and I think about this models:
- Audiotrak Maya U5
- Creative SoundBlaster X-FI
- Asus Xonar U5
What are you think about this 3 cards? What card will be the best option for my requirements?
i5-4690K @ 4,5GHz // Asus Strik GTX 980Ti // 16 GB DDR RAM 3  Kingston Fury // MSI Z97 PC Mate // Thermaltake Smart 530W // Corasir 300R
https://linustechtips.com/topic/774554-external-usb-sound-card/
I'm currently using U7 - the difference is that you would have 5.1 channels and I have 7.1.
I would suggest you to buy USB microphone - it would be cheaper and better.
You can find nice used microphones for pretty good price.
If you want to stay with your jack pick do not put your mic on max - leave 5% off because sound will be extremelly bad - even worse than sound from internal card.
https://linustechtips.com/topic/774554-external-usb-sound-card/#findComment-9775737
