So let's start with shutting down, so sometimes when I try shut down my PC the power button on the case doesn't work and the button under the settings to shut it off doesn't work also. So I was going on LTT to explain this problem and then my PC just shut down, so the problem was a late shut down and when it was shutting down it took like 10 mins to shut down. This happens when everything starts getting glitchy since I've downloaded the latest Nvidia driver.
So when I do shut down my PC two lights are always on (this always has happen, even before the new GPU driver) one light is on the GPU its a white one, couldn't find it anywhere on the manual. And the light on the motherboard is the power on light which is in the picture below.
so on the bios/trident z RGB/CAM problems I contacted NZXT about that and currently working on it but before I contacted them I uninstalled the trident z RGB controller because it wasent working so when I went to reinstall it it said I need the lastest bios version, though without the trident Z RGB program the RAM is still working fine including the lighting. (So should I update my bios because ASUS has this like bios restore point thing)
I think you know my problem about the lastest nvidia driver and I'm just getting your opinion of should I uninstall it using DUU, wait for a new one, or if I uninstall it with DDU I should make a restore point.
CPU voltage
so when I OCed my 6700k I have to flip this switch on the motherboard, but that was just a test so I'm currently not OCing and was wondering if I should flip the switch back to normal, because sometimes when I'm on CPU Z or ASUS AI suite I see my 6700ks voltage go over 1.4volts and that's unsafe. (There is a pic below that has that part on the MB manual)
Sorry for the really confusing thread and if you could answer just one of my problems that would be great
Thanks
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
https://linustechtips.com/topic/771387-problems-with-pc/
There's one LED on my mobo that is always on. It's just telling you the PSU is supplying power to the mobo.  For shutting down, make sure and close any open programs so they don't slow it down.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/771387-problems-with-pc/#findComment-9735151
