Dayz resolution issue. Need help!!
Go to solution Solved by MVPernula,
3 minutes ago, sivert456 said:
Well thank you for the tip, but it seems that Dayz does not have a "borderless" option, only windowed and fullscreen. I have tried all of the options there but nothing works.
Make sure all the settings are applied correctly, try replace 1080p with a lower res, apply, and put it back.
When in the menu, try using the keyboard to move around it since your mouse is unaccurate.
Try to get in to video settings and turn on "Borderless windowed" if you use "Fullscreen", and vice versa.
Hopefully that fixes it.
EDIT:
Oh, and welcome to the formus :P
EDIT:
