First of all, my specs:
CPU: I5 4690K
Cooler: Cooler Master Hyper 212 EVO
GPU: MSI RX 480 Gaming X 4G
Mobo: MSI Z97S SLI Krait Edition
PSU: Cooler Master G650M
2 harddisks and 1 ssd
OS: Windows 7 64 bit
So here's my problem: My pc will randomly lose power while gaming and power on a few seconds afer it lost power.
It just happend to me twice while playing euro truck simulator 2 multiplayer and has happened while playing battlefield 4.
I'm thinking it's a PSU issue but I'm not really sure, hence this post.
To Infinity and Beyond!
https://linustechtips.com/topic/770940-pc-loses-power-while-gaming/
Same thing happened to me while playing Rust.
I narrowed it down to the PSU being chinesium (not really the case for you) and I also noticed it happened when the GPU power draw went over 120W (Sapphire RX480 Nitro+). Solved it by limiting FPS in Rust (to 62) and power limit on the GPU to 115W.
Changed my PSU and mobo since then, so I have no idea if that still works
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
It could really be the PSU, I think you should get a different PSU, and test it, only then we will know for sure.
Main Rig: EK custom loop |2700x @ 4.25 Ghz| Msi X470 Gaming Plus | 32gb DDR4 | Aorus GTX 1080ti @ 2088 Mhz | TT Core X71 TG | Samsung 970 Evo Plus 500gb + 256gb Toshiba NVMe + 275GB Crucial m.2
Laptop: Surface Book 2 15" |  i7 8650U 4.2 GHz | 16gb DDR3L | GTX 1060 6gb | 265GB NVMe SSD
https://de.pcpartpicker.com/list/9jvNnH
I was thinking of doing that since I thought I didn't have any warranty, but it turns out that I still do have warranty so I don't really want to do that :(
I mean...you could just make use of your warranty then
Good to know, will monitor the gpu's power draw and see if that's the culprit. If so, I just need to replace the PSU?
PSU should handle the load just fine. Might be some sort of reminiscent power draw bug from the PCI-e. Or your PSU might just be getting old
I know it should handle just fine, that's what I think is so strange. But yeah, I think I have this PSU for about 2 years, so it might be getting old..
My pc lost power again while playing ets2mp, gpu power draw didn't even reach 100 watt according to msi afterburner.
Is there any way I to know for sure that my PSU is broken?
Oh and btw, I'm fairly certain that it's not my GPU since I recently got a replacement as my old R9 380 broke..
edit: just crashed again while playing farming simulator 17, get's fairly annoying crashing 3 times a day, which it usually doesn't..
Edited by arendsoogg
