Schiit DAC+AMP help
Go to solution Solved by Dackzy,
1 minute ago, IAR117 said:
So based of this, would it make more sense to buy a fulla 2 now or magni 2 and get a modi 2 in a year following? Also will the amp on the fulla 2 be alot worse than the magni 2? Thanks
just get a fulla 2 and be done with it.
A magni 2 will have more power and a schiit stack will be better quality wise, but I wouldn't recommend getting a stack over a fulla 2 for your headphones, plus the fulla 2 has enough power for most headphones....
Hi. Noob question, can I use the Modi 2 or Magni 2 by themselves via USB to a PC? If so which would make more sense to buy? Also would just getting a Fulla 2 be sufficient for (currently) Grado SR80is and in future some planars, not sure which though. Also what is the difference between the Schiit Ubers and non ubers? Thanks
https://linustechtips.com/topic/770070-schiit-dacamp-help/
You cannot drive headphones with a modi 2, you need an amp like the magni 2 to go with it.
The magni 2 would hook up to your PC with a RCA to TRS cable and therefore use your onboard DAC.
The Fulla 2 will be more than sufficient enough for the SR80i's
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/770070-schiit-dacamp-help/#findComment-9720923
https://linustechtips.com/topic/770070-schiit-dacamp-help/#findComment-9721853
https://linustechtips.com/topic/770070-schiit-dacamp-help/#findComment-9721872
If I were to get a set of HE400i or HD6XXs, would the Fulla be able to drive them?
https://linustechtips.com/topic/770070-schiit-dacamp-help/#findComment-9722245
yep
https://linustechtips.com/topic/770070-schiit-dacamp-help/#findComment-9722411
