Hello!
I'm currently using a laptop but this will probably change soon :o. It just can't handle some tasks I thorw at it and the thermals are bad as well. I had some crashes in the last weeks when I didn't activate the cooler underneath it. I know that this problem could be fixed but an upgrade is needed anyways.
So here are my expectations: I want to be able to play some games. I don't really play any graphical intense games and I'm using a 60Hz 1080p monitor. But gaming isn't the only thing I want to be able to do. Some light content creation should be possible as well. And this is the bigggest porblem with my current laptop.
The parts:
CPU: AMD Ryzen 5 1600
This CPU seems like the best CPU for me since it can handle everything I want to do and it comes with a decent cooler. Maybe I will replace the cooler later.
Motherboard: Gigabyte B350 Gaming 3
This motherboard has lots of features for a B350 mainboard. But feel free to leave some other recommendations!
RAM: 1x8GB Corsair Vengance 2400
Yes a single stick. The second one will probably follow soon and I don't want to buy 4GB RAM stick in 2017.
GPU: Probably a RX 470/480
I'm just waiting for a good deal on one of those. :D
Case: Fractal Design Define R5
I just want this case. Even though a cheaper case would make this build more balanced but the case is one of the components that can be used for multiple builds.
PSU: Probably something like a EVGA Supernova G2 or Seasonic Prime (550W-650W)
I want a good PSU.
Storage: I already own an SSD that I will use again. An 1TB WD blue 7200rpm will be added as well.
Feel free to leave some recommendations for me. What do you think about this build?
Thanks!
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/769623-laptop-replacement-build/
Solid build overall - I'd recommend both of the units you picked, as well as G3 and P2. Maybe even Seasonic G/S12G if you want to save some money.
Nothing wrong with one stick of DDR4. Here's the thing - for gaming, it makes NO DIFFERENCE if you have dual-channel or not. It makes small-med gains in content creation IF you're using RAM based tasks like RAM restores in AE or Premiere.
idk
https://linustechtips.com/topic/769623-laptop-replacement-build/#findComment-9715311
Thanks for this information!
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/769623-laptop-replacement-build/#findComment-9715340
