Hey guys, a few days ago I posted about what steering wheel to get, and I got the G25 from Logitech. I've installed everything so far, but there's a problem. No matter what AC adapter I try, I can't get the "power" light on the shifter module to go full green (it flashes in full brightness a few times after starting up, but then goes dim). I'm pretty sure the required ac adapter would be 24v and 1.75 amps, but I don't have anything in my house with that number. My question is, does it actaully need the full 24v, or could I just use one with a lower voltage and higher amperes?
https://linustechtips.com/topic/768142-g25-steering-wheel-issues/
You can only use a 24v adapter (± a few volts), that has at least 1.75amps
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
Didn't know that, I do have some adapters lying around that say stuff like 18+ volts. Would this indicate a bit over 18 or all the way up to 24?
