hi
I have been planning a new computer for some time and I am planning to get a EVGA Hadron case with a GTX 780
but i dont know if it is better with the reference designe that blow most of the air out of the case or just to get a better looking non-reference
i would best like to have a non-reference but will the heat inside such a small case be to much or should it be fine
https://linustechtips.com/topic/76499-reference-vs-non-reference-in-mini-itx-cases/
The heat in the case shouldn't be a problem as long as you have good airflow, I would go for a non reference card.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
non reference is ALWAYS better
unless your case is completely closed and without fans
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
no, even with most blower coolers, lots of the hot air is still inside the case. the non refernce coolers will always be better built and the fans keep the air moving past other components. the only time a reference cooler will outer preform a non reference one is if the pc is in an air tight case
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
How about NO?
Really depends on you case of choice, put a non reference card on ft03 mini and youll have a pc and a heater beside you,
As for hadron, a non reference card will be cooler than a reference one because of the nature "most non reference cards are cool and quieter" AND because it has enough exhaust to pull the hot air from the gpu out of the case. Unlike ft03,sg05,sg06,cm elite 120/130 etc as for these lack exhausts thats why non reference are i think better,
I will just assume you never built an itx machine from the posts you made, either you said it by pure speculations or really havent tried different gpu on different itx cases
Go with a reference design cooler like this EVGA GTX 780 http://amzn.to/1d2EWSS
Intel Core i7-8700K @ 4.8GHz | Corsair H110i GTX | EVGA RTX 2080 XC | Asus ROG Maximus XI | Intel M.2 nVME SSD 1TB | Samsung 850 EVO 2X2TB | 32GB G.SKILL Trident Z 3200MHz CL14 RAM | EVGA SuperNova GS 1050W | Kept cool & quiet in a Fractal Design Define R5 Window with all Noctua fans
