Coolant Ratio Help.
Go to solution Solved by vorticalbox,
1:9 for every 1 you have 9 of the other. so for 100 ml : 900 ml
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/762866-coolant-ratio-help/#findComment-9639967
