just make one. just strip the -/+ leads and connect to the battery.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/762375-fan-on-9v/#findComment-9633622
OK then find a USB TypeA connector and a female 4-pin fan connector, cut the cables, solder the correct leads in, and away you go. this should not be that hard to figure out. if you're looking for something you can just outright BUY, i can't help you.
System specs:
https://linustechtips.com/topic/762375-fan-on-9v/#findComment-9633737
Oh ok thx. That doesn't seem too difficult
https://linustechtips.com/topic/762375-fan-on-9v/#findComment-9633757
Ok so can I just leave the controllers out and just have it run on the positive and negative. Sorry I'm new to rewiring
https://linustechtips.com/topic/762375-fan-on-9v/#findComment-9633844
yes, absolutely. the motors in the fans themselves are still DC motors.
System specs:
https://linustechtips.com/topic/762375-fan-on-9v/#findComment-9633881
