Hey guys, need help on buying a charger for my laptop. The battery is an 11.1V 4400mAh 48.84Wh battery. My old charger outputs at 19V 4.74A  90W.
Heard that I should buy the same voltage to have a safe charging. What voltage is that? Should I buy a charger that outputs at around 11.1V or higher? Is using a higher V bad? Is using a charger higher than 90W bad? Im very not knowledgeable about this. Thank you
https://linustechtips.com/topic/759561-laptop-charger-help/
Sorry, my link was old and didn't work correctly.
Here is the information you need:
https://www.groovypost.com/howto/choose-right-power-adapter-charger-phone-laptop/
Edited by pete_agreatguy
Corsair 750D Case | Antec HCP850W PSU | Asus P6T | Intel i7 920 @ 4GHz with Thermalright Archon SB-E X2 |
2x 4GB G Skill PC3-12800 | EVGA GTX760 2GB | s/g 480GB SSD + 2TB + s/s 250GB SSD | Win 7 Ultimate x64 OS
https://linustechtips.com/topic/759561-laptop-charger-help/#findComment-9599970
