Hey guys,
I have created a list for computer parts, I mainly a designer but also a gamer so I will utilize all four of the monitors mentioned. But need help to see if i could improve the whole setup anyway. I already have a computer but first time building one.
Cheers!
https://au.pcpartpicker.com/list/qXnsxY
https://linustechtips.com/topic/757051-need-help-with-new-build/
What programs do you use for your design work?
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/757051-need-help-with-new-build/#findComment-9571478
For starters, if you are going to be 3d rendering I think 32GB of memory is a good upgrade. Also perhaps a Ryzen CPU is better because of the cores. I would get a better headset. Also a GTX 1080TI? Save $100 and get a cheaper motherboard. Something like the Asus STRIX Z270H will do.
https://linustechtips.com/topic/757051-need-help-with-new-build/#findComment-9571509
1 minute ago, Jamlons said:
Currently doing graphic design in Uni, mainly images but have done some 3d model renders before.
Your list is fine. Although a m.2 ssd would be better than a regular ssd.
Also don't forget to check the sRGB & adobe rgb values of the monitors for better color accuracy.
https://linustechtips.com/topic/757051-need-help-with-new-build/#findComment-9571510
Yeah thats why i chose the ASUS for its incredible colour accuracy
https://linustechtips.com/topic/757051-need-help-with-new-build/#findComment-9571519
Does look really matter that much to your build xD?
Dropping all the insanely expensive addons you have, you can save over $300.
RYZEN with ECC sounds great. like i said if you still want looks, then get some ram covers for the ECC ram >.>
https://linustechtips.com/topic/757051-need-help-with-new-build/#findComment-9571529
