Hi, im going to build a PC. And i just started to think about how i should cool it. I have bought a MSI seahawk 1080 with 120mm fan watercooled AIO and an NZXT x62 AIO cooler. Am going to fit this inside an H440 case. So i wonder if i should take the CPU cooler at the front or top. Whats best. (Have an i7 7700k)
https://linustechtips.com/topic/754783-aio-cooling-need-help/
Not going to make a great deal of difference either way, but using them as an intake might result in slightly lower temps (like 1-2 degrees maybe). Just mount them where ever is easiest.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/754783-aio-cooling-need-help/#findComment-9545867
Ok, Thanks! I was first planing it on the front and was unsure but now ill use it at the front.
I thougt it was a bigger difference then that inn temps. Like 4-5 degres. Do Thanks to you Ryoku!
https://linustechtips.com/topic/754783-aio-cooling-need-help/#findComment-9547384
