i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/75473-led-fans/#findComment-1034083
Personally I would get non-LED fans and just get LED strips. Looks less like a "gaming" computer.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/75473-led-fans/#findComment-1034122
I have heard that the led strips ware out pretty easily? is that true and if so then what do you recommend?
Bitfenix Alchemy, I don't use them but everyone including Linus uses them and read a few reviews that they like them. Also I think the NZXT hue is a good choice also for multiple colors.
https://linustechtips.com/topic/75473-led-fans/#findComment-1034173
do they come with mounting velcro or something or what would you use?
Both the Alchemy and Hue come with a 3M sticky back tape (forgot what it's called) and you can place it anywhere in your case.
https://linustechtips.com/topic/75473-led-fans/#findComment-1034232
ok and last question, im getting a corsair 350D case, what are some non led case fans some 120mm and some 140mm that would look good in a black case? I might try the strips instead of LED fans too now...
https://linustechtips.com/topic/75473-led-fans/#findComment-1034498
I would say Silverstone AP122 for 120mm fan and Bitfenix spectre pro non-led for 140mm those are some that come off the top of my head
https://linustechtips.com/topic/75473-led-fans/#findComment-1034634
