gaming only or also doing streaming/editing/rendering?
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9527713
PCPartPicker part list: https://pcpartpicker.com/list/mb8xPs
Price breakdown by merchant: https://pcpartpicker.com/list/mb8xPs/by_merchant/
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  ($214.99 @ Newegg)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.99 @ Newegg Marketplace)
Motherboard: MSI Z270-A PRO ATX LGA1151 Motherboard  ($114.99 @ B&H)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($94.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($94.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1080 Ti 11GB Founders Edition Video Card  ($698.99 @ SuperBiiz)
Case: NZXT S340 Elite (Black) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($88.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.58 @ OutletPC)
Total: $1570.63
Generated by PCPartPicker 2017-03-16 07:34 EDT-0400
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9527726
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($327.99 @ SuperBiiz)
CPU Cooler: Enermax ETS-T50 AXE (White) 62.3 CFM CPU Cooler  ($51.99 @ Directron)
Motherboard: ASRock Z270 Killer SLI/ac ATX LGA1151 Motherboard  ($122.98 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($88.89 @ OutletPC)
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive  ($67.88 @ OutletPC)
Video Card: MSI GeForce GTX 1080 8GB DUKE OC Video Card  ($494.98 @ Newegg)
Case: Phanteks Enthoo Pro M Acrylic ATX Mid Tower Case  ($71.00 @ Newegg)
Power Supply: Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($92.99 @ B&H)
Total: $1503.68
Generated by PCPartPicker 2017-03-16 07:37 EDT-0400
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9527737
Total: $1503.68
Do you think a 7700k with 1080 would be better than a 7600k with 1080ti?
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9527744
the i5 struggles with the gtx 1070 in newer AAA games.
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9527749
14 minutes ago, ops19 said:
I like the 1080ti one
the i5 will very likely bottleneck the gtx 1080ti, it is already struggling in games at 1080p with a gtx 1070. you'll also get more fps drops and stuttering with the i5 compared to the i7.
i would recommend my build; you're getting a cpu that will provide much smoother framerates with less fps drops and stuttering, a far better cooler, double the hdd capacity and the option to SLI later on.
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9527811
3 minutes ago, ops19 said:
Ya I get what u are saying. I think I will try to save up and see if I can get the i7 and the Gtx 1080ti. Will that be a good build
yes, that will be the best. but if you aren't running a 1440p 144hz monitor or 4k monitor, you probably don't need a 1080ti.
if you don't mind cheaping out on some parts and getting windows from reddit for $20-30/run it deactivated:
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($24.88 @ OutletPC)
Storage: ADATA Premier SP550 240GB M.2-2280 Solid State Drive  ($69.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.88 @ OutletPC)
Case: DIYPC D480-BK-Window ATX Mid Tower Case  ($49.79 @ Newegg)
Power Supply: Rosewill 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg)
Total: $1511.48
Generated by PCPartPicker 2017-03-16 08:21 EDT-0400
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9527900
Total: $1511.48
Great build, but imho i would buy a 7700 non k with a b250 motherboard and with those 70$ that you save i would buy a bigger ssd, or a nicer case
https://linustechtips.com/topic/753062-build-for-under-1500/#findComment-9528101
