Try alt+f4. If that works, then run the software again and see if it completes the process.
Or you could close it though task manager.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
1 minute ago, Indonesian said:
Same issue still, stuck there doing nothing.
Are you using the latest version?
17.0.5.3
Just now, Indonesian said:
Im using an even later version, 17.0.6.0
Didn't know they'd updated. Well I'm using the one I posted, so maybe you could try that. Could be a bug in the latest update.
So i decided to system restore and just manually uninstall. But turns out the uninstaller wont show up. So i'm forced to use device manager to uninstall. Gonna see if everything's fine.
Been using DDU for years with my gtx 780, but now i dont think i want to use it anymore...
Pardon my ignorance but why use DDU instead of device manager? Arn't you using no essential just bloating your machine with non essential software?
32 minutes ago, AlexCo said:
i've always used Add/Remove Programs & Device Manager to remove the drivers with good luck... not sure why you need a third party app these days.
Probably cleans up some left over files that you don't need, which in any case don't do any harm. I guess people are anal about it
y are you doing that firstly just download new driver from nivida and it cleans the old driver out for u once u unlock your pc
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
