Need Help! Add Storage/Drive On PC Guide
By
muzakkifatch
in Storage Devices
in Storage Devices
Solved by Guest,
You most likely need to format it/add an drive letter. "mount" it. Search for an guide/tutorial for adding drive letters + your operating system name in google, and you should find your answer.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
