so I am building a new rig and I am concerned about this air cooling fan https://www.amazon.com/gp/product/B0177GTV9U/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2ZKSOM6XK2G3G
and I have this motherboard  https://www.amazon.com/gp/product/B01MR32I8L/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
will this fan capable to successfully mount onto the CPU socket?
https://linustechtips.com/topic/751366-need-help-with-a-cpu-fan/
According to newegg that cooler fits the lga 1151 socket, so ya it should mount fine.
Edited by LordWaffleGoblin
I suck at typing
-CPU-
AMD R7 1800x
-GPU-
XFX Radeon R9 290x
-STORAGE-
ADATA Premier SP550 480GB
 Toshiba 3TB
-RAM-
G.SKILL Ripjaws V Series 32GB (4x8)
-PSU-
Evga 850w G2+
-MOBO-
ASUS Prime X370-Pro
-CASE-
Corsair Obsidian 750D
-PERIPHERALS-
2013 Razer Blackwidow Ultimate
Logitech G302
-PART PICKER URL-
https://pcpartpicker.com/list/vrqdQV
https://linustechtips.com/topic/751366-need-help-with-a-cpu-fan/#findComment-9508551
pc part picker it and it should (going from what the other guy said)
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/751366-need-help-with-a-cpu-fan/#findComment-9508578
Yes it will. But what case and CPU are you going to use? C7 is down-draft cooler and lacks some cooling power compared to single towers (like Cryorig H7).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/751366-need-help-with-a-cpu-fan/#findComment-9511486
I will be using i57600K 7th Gen Core and Rosewill TYRFING ATX Mid Tower Gaming Computer Case. I am not planning on super overclocking the CPU yet. Would suggest a water cooling for that.
https://linustechtips.com/topic/751366-need-help-with-a-cpu-fan/#findComment-9511885
No AIO needed. I would suggest getting Cryorig H7.
https://linustechtips.com/topic/751366-need-help-with-a-cpu-fan/#findComment-9512684
